I wonder if anyone can help in regards to problems with my blow heating.
I have a Truma C 603 E which appears unable to ignite on 12 volt and give me hot water or blow heating.I have plenty of gas and the leisure battery is fully charged.Every time I try to start the system the control panel red light comes on indicating a problem. The handbook suggests the cowl might be blocked, I have checked this and it appears ok, the gas feed appears fine although I have no way of checking this apart from making sure no valves are turned off.
When I switch on to 230 everything appears to be normal in regards to heating the water (no blow heating on this model on 230)
I have checked fuses and had a look to see if there are any obvious signs such as loose wires etc but all apperars fine.
Any help would be greatly appreciated.
