Hi all
I am after some advice on my Truma motor mover. I purchased the van with this already on. Its one of the earlier ones, with manual engage/disengage and the rollers are the gravel type stuff, not the groved alloy ones (if this makes sense?).
The issue i had the first time I used it was, it moved the van for about 30 seconds, then cut out. When i switched off the remote and switched it on again, it did the same, moved for 30 seconds then stopped and so on. Since then i have not used it, as i am not too bad at using my car to reverse (plus only been out once and had the van less than a month).
Does this sound like it could be the batteries in the remote? The issue i have now is that there is another van at the side of mine in the storage yard, and this means that using the mover would now be ideal and would save a lot of sweat and tears!
My battery is showing in the green on the battery status (it is the needle type and doesn't show any volts, just red, yellow or green).
Any help would be greatly appreciated
