Truma motor mover issue
Aug 4, 2004
4,343
Last week we tried to level our van using levellers, but although the motor mover rollers would turn they would slip on the wet wheel. I contacted Truma about this and they said that as levellers have a slope gradient of 1 in 4 and the Truma can only handle a 1 in 10 gradient this may cause the rollers to slip. In addition, if the tyres are of the Hankook variety as the compound is harder than normal, this may also cause the rollers to slip if the wheels were wet.
Surely if the motor mover would not work on certain makes of tyres that are used on caravans, this should be stated prior to one spending £1400. As levellers are generally very short and only used on one side of the caravan, surely the other side should have enough impertus to move the caravan up the leveller.
Are they trying to pull the wool over my eyes or is this genuine and I have to either get four new tyres or the motor mover replaced with another?
May 12, 2005
470
I had a similar problem,and never did get the mover to climb onto a leveling wedge, I overcame the leveling issue by making a cradle that supports the tyre on both sides and jacks up with a bottle jack the jack is replaced with wooden wedges when at the correct height, a similar thing can be purchased from Towsure page 90 2005 catalogue
good luck
