Our caravan has the Truma Ultraflow sytem with a submersible pump in the Aquaroll. We have noticed the flow from the taps is not as fast as we would expect. It seems that the pipe from the Aquaroll to the side of the van is quite a hard plastic and where the pump has been stored in the sink,the plastic has creased and left a retriction in the pipe. What are your views on replacing the pipe with a softer plastic such as the ones used on Baileys with the inboard pump system. On the Truma website the picture of the pump assembly shows the outer sleeve of the pipe as having what I can only describe as pinch points in it. Could it be that we are expecting too much from the submersible pump system as our previous van had the inboard pump system and that delivered water from the taps a bit too fast at times.Our caravan handbook describes the Truma sytem as 'pressurised' whatever that means.
