Truma Ultraflow Surge Damper and pressure switch
Hi All, I'm after an opinion from those who have the above pressure switch installed in the water system. We have a Coachman Pastiche, and since new every time a cold water tap is turned on, there is a groan noise from ythe pressure switch. Not all the time, but just when switching the tap on. If the tap is turned on to full quickly, you dont hear the noise. It is most annoying at night if anyone gets up for a drink or whatever, as the pressure switch is just below the pillow. Happens every time, not intermittent.
I reported it after the first outing. "We'll check at the first service" - Result = no fault found.
Just picked van up again today after second service - Result = no fault found!
I cannot believe that this noise is a design feature of the unit, I do believe I have a faulty unit and after 2 years I'm still trying to get it fixed. The authorised dealer is 70miles away, hence why it's taking so long.
OK, it still works, but the noise is so annoying!! I need feedback to say if this is a one off issue so I can demand a replacement unit, or if they are all like that.
Thanks in advance
Don
Thanks in advance
Don
