Turning Yellow
Feb 15, 2007
259
I have a 5 year old van and clean it regularly but since picking it up after the winter and cleaning i have noticed the front starting to turn yellow what is this and how can i get it back to white?
Jul 15, 2005
2,175
Anthony,
If the yellowing is on a plastics panel, and that panel gets the sun whilst in storage - then it's almost certainly photo-chemical ageing of the plastic.
If it's a painted metal panel, or a panel on the north-facing side of the van - then it's some form of atmospheric pollution - like smoke - but that's hardly likely.
If it is sun-induced fading of the plastic - then you might like to make a careful examination of the surface - and report back. Does the very top layer look chalky? and so on.
But your choices may be: living with it, trying a cutting polish (like T-cut) to remove the microscopic coloured layer, protecting with a good wax, repainting the panel...
Robert
937
Anthony, the yellowing is, unfortunately, a process of light damage to the panel, probably due to not enough stabiliser being added at manufacture.
It is possible to restore it, the level of success is somewhat a case of just seeing how well.
You could try a UPVC restorer which is applied using a polishing machine, then after that treatment, a good quality polish, such as Autoglym, or Mer.
It has been suggested that T Cut also works, much in the same way.
Feb 6, 2008
96
T-cut is not one of the products we have ever found work well. Also the use of a machine mop is not for the faint hearted as you can cause more damage than good. To save yourself the work and hassle and to get the job done correctly, I suggest you find your local bodyshop and ask if they will be willing to machine mop the front panel. This should cost you around £100 and if it's done correctly, you should be left with a front panel that looks as good as the day it was built.
937
If one looks at the original posting date it was 2008.
One of the contributers is now dead (RIP Rob)
God only knows why this topic was added to after 2 years dormant.
