- Sep 23, 2023
- 1,082
- 413
- 1,435
I am shortly going to fit a TV into the caravan(I've no choice I'm under orders) am I correct in believing the shorter the co-ax the better Thanx ... Gary
Remembering that amplifiers will boost interference as well as the signal.Your caravans tv amplifier will add a second string to your bow in boosting then signal.
Just a thought, have you tried feeding the signal in through the connection in the battery box, but switching OFF the amplifier.Remembering that amplifiers will boost interference as well as the signal.
I've found that when a site provides a TV point, the strongest signal is by feeding our 25m co-ax cable in under a window seal and straight into the TV - using the entry point in the battery box and boosting with the amplifier gives a poorer signal.
There are amplifiers with variable gain and filtering so if the OP doesn’t already have a built in OEM unit he could look at Maxview or Visionplus. But if signal to noise isn’t good then as you say even filtering may not help much. Time to get the cards out I seem to remember my last van (2012) had one with two gain levels but it wasn’t something I ever adjusted, but I did carry a tv pole, external aerial and a long coax as fallback.Remembering that amplifiers will boost interference as well as the signal.
TV satellite transmissions are guaranteed until 2028, the satellites themselves reaching end-of-life in 2030 - we've had our Freesat receiver 15 years so I don't feel a need to get any money back for it.One thing to consider re Freesat is that as Sky moves on line rather than using a satellite link mainly due to the satellites reaching the end of life and it's just not financially worth adding new ones.
Sky have said 2029 at a minimum but could be anytime after that.
I have just ditched all my sat stuff at home and gone on line/ terrestrial whilst there is still a market for the set top boxes.
The same will happen to Freeview leaving us with little choice but to use on line services.
I would think that there is a several or more years before everything moves Online. Many people still do not have Internet access probably because they have no interest or it is unaffordable to them.One thing to consider re Freesat is that as Sky moves on line rather than using a satellite link mainly due to the satellites reaching the end of life and it's just not financially worth adding new ones.
Just like a certain type of cars that was supposed to be phased out by 2030, but has now been moved back. Same will happen by 2030 as probably hundreds of thousands of people still will not have access to the Internet. Again same with FM broadcast which will still be with us for the next decade or more. In some areas DAB will not work, but FM will. Just driving to our place and we are not far from town although rural area, we constantly use DAB. This also happens in town areas when between tall buildings.As has been said the EoL of the satellites is 2030, Sky have guaranteed broadcast until 2029.
That's less than 5 years away.
Terrestrial TV will stay for a bit but BBC director has said it will be all on line in the 2030's whether that is the beginning or end of the decade who knows.
