Two into one waste water outlets
Jun 5, 2005
52
I am sure I remember seeing , some time ago, an advert for a two into one waste water outlet ,these plugged into the waste outlets and then just the one pipe going into the waste water container. Does any one know if these are still available and if so where can I get one??
thanks in advance
Tony
Feb 16, 2009
1,144
Any caravan dealer accessory shop has them, their are different types for different waste pipes.
NigelH
Jun 5, 2005
52
Guess I must have been looking in the wrong place each time I've searched for them, thanks I'll ask the next time I'm in an accessory shop
Jun 14, 2009
8
Bought one last year off e-bay the thing has been in shed since thought it was a waste of time 2 bulky and fiddly to fit.Bought a piece of plastic pipe and a plastic y piece in the end much easier to use as u can cut the tubing as long as you want it.Dont waste your money in my opinion when you can make better yourself.
Jan 20, 2009
56
One thing to note, in the event of a restriction in the joined exit pipe, your sink/kitchen drain will fill up your shower tray, YUK.
geo
Oct 24, 2007
96
Hi Tony
I made one up myself, one tee, one street elbow two short pieces pipe, plus short pieces of flexy pipe, cost around
Jul 25, 2007
293
Either just buy a Y shaped connector and make one up from 3 sections of waste pipe or buy one from the caravan accessory shop. I have had no trouble with my one (which I made up) causing back up of waste.
