Alan, I agree with what you are saying, I would have thought that if your payload is 250kg, then the pressure would be the same if the caravan is empty or fully laden.I'm sorry Chris but I have to disagree with your interpretation. If you interpolate your graph there would be a point where you would run the tyre with no pressure. Think of your car from running with driver to fully loaded, the chances are that you change the pressure by only 10%. 21psi would be grossly under inflated for any tyre increasing the risk of blowout, instability, tyre wear, etc.
If an owner does not have the maufacturers hand book with the correct pressures in them then a tyre dealer or caravan dealer should be able to advise the pressure, which is likely to the pressure for that tyre and accurate to within 10% for the load of the van to which it is fitted. If for the 195/70R14 example you give the pressure for that tyre is going to be 36psi - no variation, (you do not have to inflate tyres on a new van once you own it because you have loaded it).
The data was taken from the Continental tyres website.Thanks for your further comments.
AlanW;
Where did your tyre dealer get his 36psi from?, if he looked at the BRMA booklet he would see that 25psi is listed for a 450kg load (195/70R14), is his manufacturers association wrong? I suggest he just guessed it. So anyone taking his advise for a 900Kg van would be 44% overinflated!, would you run at that figure?
This pressure/load is the lowest table figure for that particular size, I accept I have extrapolated my 21psi from the graph, but based on the fact that the line is straight, and other sizes give figures down to their 40% loads. So I consider the extrapolation reasonable, but only down to 40%, which I have already stated.
If you phone the BRMA they will post the booklet foc, please plot out the graph and I think you will follow my reasoning; perhaps a good exercise for your students?
Lutz;
Thanks for the table, it matches the one in the booklet, and the points are "on the line" of the graph.
Are you able to disclose where it came from, as, apart from the BRMA booklet, I could'nt find such tables last year?
