Picking up on Clives post, while if the original tyres are being used to their limit, it is always a good idea to raise the load index of the new caravans tyres, it must be remembered the required pressure is going to change.
Taking the two tyres clive mentioned, these are totally different in their construction and the pressures for a given load vary widely. The original 195/70x14 96LI is a 'reinforced' tyre and these have a maximum pressure of 42psi
However the 185/75x14 102LI is a 'light commercial tyre', (what used to be called 6 or 8ply') this has a maximum pressure of 69psi, actually this particular tyre has a higher stated max pressure than any other, the rest of this type are either 54 or 65psi, depending on their exact construction.
So, taking the original 195/70's at the max pressure, they can carry 1420kg per pair. On the other hand, the 185/75 carries 1700kg at their highest pressure and would need 55psi at 1420psi, so would be 13psi under pressure if the original tyres pressure was still assumed to be correct.
Finally, while the 185/75 is more available, it is still not a prefered size, for a slight increase in the caravans ride height, (approx 11mm, 3/8"), the 185/80x 14 102 is the more popular size and because of that, a lot cheaper. This tyre using the same example needs 52psi at 1420kg
