Under Caravan Treatment
199
19,235
jondogoescaravanning.com
The floors of caravans are manufactured from exterior grades of plywood which use glues that won't absorb moisture therefore they don't require any further protection.
Sep 24, 2008
925
240
19,135
It is only the ply laminates which are "glued"and the black coat is preservative which over time does wear away leaving the surface open to the elements. I have sprayed mine in places where this has happened. After all its only ply and not something special apart from being a waterproof ply( i hope).
Sep 25, 2008
133
it is usually pressure treated marine rated ply. nothing should ever be used to underseal. it will stop the timber from breathing and will cause the timber to sweat and rot.
