Does anyone tow with one of these German auto boxes. Just wondered if they are man enough for lots of towing.
Dustydog said:Does anyone tow with one of these German auto boxes. Just wondered if they are man enough for lots of towing.
JezzerB said:...
The experts answer is here;
https://www.honestjohn.co.uk/askhj/answer/73577/how-reliable-is-the-dsg-gearbox-
ProfJohnL said:JezzerB said:...
Experts???
I have found some of HJ;s comments a little suspect in regards of some vehicles.
ProfJohnL said:To be fair OC, this thread is about VAG DSG's not Ford Powershifts or any other make. Whilst I am sure the principles of operation may be similar the differences between makes could be significant. There is no reason to assume a Ford failure means that VAG will suffer the same problems and of course vica versa.
What I have read and seen suggests that some VAG cars with DSG's have had some transmission problems, but the numbers are small, and the transmission failures may have been DMF's rather than the gear box its self.
What is evident is the importance of the gearbox maintenance (i.e. oil changes etc) I can vouch for that as when I purchased my secondhand 2006 DSG 170 Passat with a DSG (74000 Miles), it was reluctant to change up when accelerating. I had a full service including gear box oil change,and the shifts happened at the right RPM and load points and have remained so since.
Experts???
Advice maybe but this isn't advice-the op asked about reliablity of the gearbox and HJ collates and helps people with issues and complaints and compiles an idedpendent database of them. I wouldn't ever take from one source-as you suggest many motoring organisations issue advice/ findings that you need to make sure yourself as far as possible is true but in this case an independent collection of findings allied with looking at the forums/ web etc maybe looking at the warranty direct findings etc SHOULD HELP the OP make an informed decision. VAG group cars don't appear to be as reliable as the 'public perception' would have you believe and the DSG gearbox has if you look around be the subject of some consternation.
Skoda group cars seem to come out far better than most VAG group cars-and you can google that for the speculation as to the reasons if you want.
So my summary advice would be 'probably' but do your research as to which gearbox you are going to have, make sure it is well maintained-if buying 2nd hand especially important as people do skimp on servicing and if you buy new not so much of an issue as you have the warranty. OP can of course take out a paid for warranty with a company-cost of that might be a reflection of the reliability of the car too!
otherclive said:ProfJohnL said:JezzerB said:...
Experts???
In this case HJs comments mirror those on other websites. Particularly those relating to Ford Powershift. My daughters has a 2015 1.6 litre Focus that has had two complete gearbox rebuilds by Ford. Even after the three year warranty had expired Ford accepted responsibility for the failure.
When towing with my Skoda I put the car into sport mode as it wanted to tow in what I felt was too high a gear which could affect the dual mass flywheel longevity. Hence running it at a higher rev point achieved by it selecting a lower gear.
:kiss: :kiss:EH52ARH said:Dustydog said:Does anyone tow with one of these German auto boxes. Just wondered if they are man enough for lots of towing.
Just because your pension money has come through, forget it
Dustydog said:Thanks chaps.
My current car is a conventional torque converter. No clutch burn.
The DSG I am looking at is 3 years old. Seems to be the wet clutch packs with like a modern day pre selector gearbox with 8 gears.
All my old motorbikes were oil immersed clutches. Never had a problem. So it does seem the more modern oil bathed DSGs will perform like a fluid flywheel torque converter with no clutch burning smells when manoeuvring. Well I hope that is the case.
OC mentioned the DMF. I have had three of those and they have all done over 100k no problems. Do they react differently on an auto box?
Are the DSG gear changes seamless or jerky???
Thanks for the pointers, DD.
otherclive said:You have no real evidence to to your comment that some DSG gearbox problems may in fact have been DMF or vice versa. But the propensity of the system to seek a higher gear does lead to high torque at low engine speeds. So whilst towing in the Superb 170ps I put the car into Sport mode which kept the engine above 1500 rpm at 50 mph with a good throttle pick up available. Otherwise I feared for the longevity of the DMF.
otherclive said:I too researched the Skoda Superb and associated VAG brands and decided that the DSG 4x4 was okay. And to be fair the DSG and DMF behaved impeccably. But I hadn’t realised that the Czechs were able to build a Páteční vůz :evil:
I bought it at 24000 miles with one owner FSSH and by 48000 miles it mirrored my Disco 2 as a confidence diminishing vehicle. Hence the recent change.
ProfJohnL said:otherclive said:I too researched the Skoda Superb and associated VAG brands and decided that the DSG 4x4 was okay. And to be fair the DSG and DMF behaved impeccably. But I hadn’t realised that the Czechs were able to build a Páteční vůz :evil:
I don't know of any vehicle where its reliability increases with age! So its really a question of comparing with similar but different makes of vehicle, and that will be very unique to each user.
I have CVT on my Subaru Forester. This is the XT model and it’s so much different from my previous XE model that had the naturally aspirated engine at 150 bhp. Unlike the XE the XT has a lot more torque as the turbo comes in and this means that even under gentle acceleration the engine revs don’t spin up rapidly as was the case in the XE variant. It makes fir a nicer drive. Towbar going on in ten days time so be interesting to see how it drives with van in tow.A vehicle with a CVT gearbox is probably a better bet than DSG. It is more fuel efficient. Many newer vehicles now have CVT.
