Vitara 1.4T AWD vs CX5 2.5 AWD
Aug 12, 2023
674
312
2,135
Recently changed from Vitara to CX5 as needed more room for our junk. Thought write comparsion towing our Adria Altea 430 caravan, 1150kg loaded.
Handling wise CX5 leaves Vitara for dead especially in high winds which hardly bother it. This comes down to pure physics, heavier 1650kg vs 1250kg, long and wide wheel base. Towing in high winds with Vitara never had me worried but it knock car around demanded lot attention and slowing down. In calmer weather Vitara handled caravan well.
When comes to engines to Vitara leaves CX5 for dead. 105KW+ 240NM 1500rpm vs 148kw+ 250NM 4000rpms. That low down torque of Vitara makes for more relaxing drive. Put it in cruise control and it leave Auto do its thing, no problem maintain 90kmh and only need to >3500rpm(3rd) on steep hills. Used Sport mode on windy hilly roads. Few 1000kms of towing never felt needed more power.
CX5 on other hand needs quite bit of important (paddle shifters) if want to maintain its speed on undulating roads and hills. Cruise control will drop 5-10kmh before shifting down to 4th or 3rd to build speed again. 2.5L isn't under powered but just needs to use gears to access its torque band.
Handling wise I've no doubt it would tow +1500kg 7m caravan with no issues. Power wise will need lot more input from driver to maintain pace on hill roads.
Not drive 2.5 turbo version but from specs suspect powerwise it would make easy work of 1800kg caravan.
Outside towing both cars are easy to live with plenty of power. Lightly loaded think Vitara is slightly quicker when it comes to over taking. Both have similar active safety system and bells and whistles. Both cars safety systems rarely beep and bong unlike others, looking at you Sportage and Outback. Couple thinks that standout with CX5.
1) mirrors that fold when car is locked. This was gripe with Vitara had electric mirrors but no option to fold on locking. No way to tell if car is locked at glance.
2) headup display thought it was gimmick on test drive but wife and I are now sold on it. Must on any future cars.
Vitara wins on economy stakes by about 2L/100km CX5 both unladen and towing. No surprise there given weight differences. But it uses 95octane compared to CX5 cheaper 91.
In summary if you own either one of these cars and looking to buy caravan. Vitara will handle upto 1200kg no problems powerwise just be careful towing in high winds or avoid them altogether.
CX5 upto 1500kg but be prepared to put bit work in to maintain pace. >1500kg probably be looking to upgrade to vehicle with more grunty engine in long run.
Reactions: Hutch and Mel
9,364
1) windows that fold when car is locked. This was gripe with Vitara had electric windows but no option to fold on locking. No way to tell if car is locked at glance.
Thank you a very useful real world comparison. A Vitara was on our shortlist but like you we decided that we required more luggage capacity. Also a lot of drivers are still not aware of the excellent drive ability of smaller engined turbo petrol cars. When friends of ours bought a 1 litre Fiesta with the eco boost engine I was amazed at how easily it took four of us up the steep hills on a journey from Bath.
My son recently bought a 1.3 Duster petrol turbo to replace his well worn diesel 2008 Freelander 2 and he’s really pleased with it and apart from being less sumptuous than the FL2 it’s still a nice car on longer journeys.
2,749
I have the 2l normally aspirated CX5. 165ps. Auto. It is supposed to be able to tow 1800kg. But I no longer tow. So have no experience. Others though do seem very happy with it. Without towing I find it a very nice car to drive. But it does not feel as though it would have enough power to deal with a caravan. I am not a fast driver and find it is fine in traffic, even overtaking. Sport mode provides a definite boost, I have only used it to try it.
You say it needs gear changes to maintain speed. Presumably this is when towing. It is not a problem I have found solo.
4,405
From past forum threads, I understand Trevermony resides in New Zealand. It is quite common for car manufacturer to sell a model in different regions of the world and to specify it differently. we have seen instances of where what was assumed to be the same model having widely different towing specifications. Also what you are allowed to tow can also be affected by local regulations.
I do not know if any of these factors apply in this thread, but it would be foolish not to check the detailed specifications of any vehicle you may wish to consider and to be aware of local regulations.
Aug 12, 2023
674
312
2,135
The towing limits vary considerably between markets. Australian/NZ versions tend to have higher tow rates, a bit to high in my option. Quite often quite a bit higher than vehicles empty kerb weight.
Jimny 3 door 1095kg is rated for 1300kg braked. Only saving grace for Jimny is gutless 1.5L means nobody is likely to tow 1300kg far for for very long before deciding vehicle is wrong tool for job.
Vitara mild hybrid is 1150-1290kg kerb weight rated for 1500kg braked.
Same vehicle as my 2021 Vitara with few more kgs thanks to mild hybrid. Unfortunately Vitara would have power to tow 1500kg so owners may not feel upgrade in tow vehicles is required.
5,387
The 2025 Hyundai has a max towing weight of 1363kg, but the same model 2026 can tow 1510kg however the 2026 is heavier than the 2025! Fuel tank and battery both the same size. Hardly any difference in spec level?
