Hi all, is there anyone who could give me any advice pleases?
Having just got back from our last holiday of this year, ready for the van to be laid up ready for the winter,
I,v a plastic 25 L water container with a tap on it, which i have on a clear half inch tube which in turn conects into the double inlet / outlet socket.
In my van i,v got a floor mounting self priming foot operated diaphragm pump, now before getting water up through the tap no problem, it came through ok, but whilst on this holiday, as you pump the pump the water container, plastic water containner, was being sucked in and very little water was comming out of the tap, i had to undo the water bottle cap to release the air out, it would work for a bit but then going back to a small trickle of water from out of the tap,inside the van.
This was very frutrating, in the end i undone the water botle and placed it on the table in the awning and held the kettle ect under it to get water .
Now is there something i can do to cure this problem, replace the foot pump,ect, is this a common problem with these foot pumps or what, any ideas please, thanks john.
