water heater
Apr 18, 2009
17
turned on my water heater last week went outside playing with the kids and i could hear big bangs didnt think anything about it till i went in the van and it was as loud in the van as it was outside turned the water heater off and it stopped any ideas
3,603
Almost certainly the appliance needs to be serviced. do not use the appliance untill it has been checked.
As it is a gas appliance this must be done by a gas competent person.
Feb 15, 2009
300
aiden this might sound mad but was there water in the tank before you switched it on i always check that there is water coming out the hot tap before switching on the heater gas/or elec
cheers
Duggie
Nov 5, 2006
805
when you connect up your water supply run the hot water supply to all tap's until all spluttering has stoped. this indicates the heater tank is full & air is purged from the system
44
19,185
This has nothing to do with if theres water in the tank or not, there is a problem wth the gas 'burner module'and as JL says, needs expert attention
