Found quite a bit of water in the wet locker this week. No signs of water ingress from the walls, window or bed above. Must have come in through the locker door seals.
Spoke the Chipping Sodbury who said thoroughly clean the rubber seal and door frame and liberally apply silicone spray lubricant. If that doesn't cure it they will supply a new seal by post ..
Do you think the claen up and silicon spray will work?
