Water pump not shutting off
Mar 31, 2016
8
Hello all
Been away for the first caravan weekend, really enjoyed it as did the Mrs which is good as we can do it again
I have a whale water pump which feeds water to the kitchen sink the bathroom sink and the toilet flush, (no flushing separate tank, is this unusual). The pump is switched on by a switch on the electrical panel with an indicator light when running. The pressure is good. The issue I have is it does not shut off, the taps have micro switches how do you test them? The kitchen tap leaks could this cause a problem? Do the micro switches send a signal based on tap position ie closed engages micro switch to send shut signal?
Any help appreciated
Taffallan
May 24, 2014
3,687
763
Does your system have the adjustable damper? I tend to think its not the microswitches if they are all doing it.
Mar 31, 2016
8
Not sure, my thought was if one micro switch was faulty this would stop the pump switching off. Is this correct? What is the damper? I assume it is to stop pressure fluctuation. Where would it be?
May 24, 2014
3,687
763
It will look like a white bottle or tube with a hand nut on top. Usual thing is to turn this nut no mre than a quarter of a turn in either direction.
If you google the term caravan surge damper you will see a pic of it.
Mar 13, 2007
1,750
a surge damper and a pressure regulator is not the same thing, a surge damper only smoothes out the the pulsations from the pump so it gives a smooth flow to the taps.
a pressure regulator, regulates the flow rate and if the pressure rises to a set rate, cuts off the pump. [like when all the taps are off] if the system the OP has uses micro switches at the taps there will not be a pressure cut off valve, there may be flow regulator, but this will not affect the switching of the pump.
sounds like one of the micro switches is faulty. a common fault, and the reason whale went over to the pressure system .
for the OP's information when the tap is closed the switch is off, when the tap is open the switch is on.
a quick test is while all the taps are off,[ pump switch on] if the pump is running go to each tap and pull off one of the terminals the one that stops the pump when disconnected, will be the faulty one, but do them all just in case there is more than one faulty.
Mar 31, 2016
8
so is the pressure controlled system the more popular, reliable option? If so is there an option to convert a M/S system if so are they available easily?
May 24, 2014
3,687
763
That is quite correct. Apologies for the confusion, its been a while since i had that system and got confused over the name. Must be age creeping in.
Mar 21, 2008
364
On my taps the microswitch is a small black plastic box about half the size of a stamp with a push switch activated by a hinged lever.
This is held in the underside of the tap head (the lever of a lever tap) with a grub screw, and the two wires fed down through the body of the tap.
Whenever I've changed them I've had to trim and adjust the lever on the microswitch.
All the microswitch does is switch the pump on when it's "unpressed" and off when it's "pressed".
If yours has become loose (in the tap head) it may cause the symptoms you're experiencing.
Whenever mine have failed they've always failed to switch the pump on.
The kitchen tap drips sometimes though!
936
If your toilet flush is supplied direct rom the aquaroll then you have a pressurised system which means you do not have microswitches in the system. The toiet flush simply activates a solenoid valve to allow water through.
For the pump to keep rung you have a setting problem with the pressure sensor, which , depending on your system will be in the inlet housing or a separate unit mound , normally, on the floor near the inlet inside the van.
If you can take some pics and post them it would be helpful.
Nov 6, 2006
731
My previous old Bessacarr had the system where one pump submerged in the on board tank supplied the whole van including toilet flush (or an outboard pump in the Aquaroll did the same job). Pump selection was made at the control panel as the OPs.
In either case the pressure was controlled by a Whale pressure switch, and taps had NO micro switches, as Damian says.
The clue here is that the 'kitchen tap leaks'. However small a leak, the system pressure will soon drop, which activates the pressure switch, followed by the pump. The system will cycle on/off until the leak is fixed, which must be done prior to adjusting the pressure switch.
The pump will turn more rapidly on 230v than 12v, thus restoring pressure more quickly. To achieve appropriate pump run times, the pressure switch should be adjusted for the chosen voltage. Whichever, adjustment is the same: activate the pump by opening then closing a tap; turn knob on top of pressure switch clockwise till no further turning possible; turn back a/clockwise until pump stops; turn 1/2 a turn more. This is the datum point - a minor adjustment either way should set you up.
936
WoodlandsCamper said:
???? I thought all caravan pumps were 12v.
They are.
However when just relying on the battery for power as the pump uses the power it will slow down as the battery discharges.
On EHU the battery is kept at full charge as the PSU is supplying a full 12v.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
swqd3r
