Hi Nothing coming out of taps. Light on main control for pump on so not fuse enough water in barrel have tried another pump but still nothing any idea what else we could try any advice appreciated Thanks Annie
Hiya, was just wondering have you switched on your 12v panel and circuit then press the tap symbol, just an idea.Hi Nothing coming out of taps. Light on main control for pump on so not fuse enough water in barrel have tried another pump but still nothing any idea what else we could try any advice appreciated Thanks Annie
submersibleIs it a submersible pump or internal? Mines an internal and I found when I put the pickup in the water barrel it floated . Modified it with a length of 12mm central heating pipe so pickup sits on the bottom of the barrel.
will post a pic if needed.
submersible
Many thanks for the feedback Annie. It helps us and all the other Forumites. Good result for you.👍Hi Mobile engineer been out today and found the pump to be faulty (despite having to take it back to where we bought it from and they said ok). He put a new filter on the old pump we had and hey presto it worked! Thankyou everyone for your advice much appreciated Annie
