Evening all, a wee problem for which I seek the advise of the collective please.
Back in January we bought a new Elddis Crusader Superstorm to replace our Swift Conqueror 630. Loving the new van and the layout which is better for us, but........
The water system has leaked, only to a small degree, but leaked all the same since day one. It's been back to the dealer 3 times now and each time they manage to stop it dribbling, usually by replacing a piece of the pipework.
The main problem is that there is a lot of (over complicated?) plumbing on a board which also has the pump and a manual change over valve on it. Every time we want to fill the onboard tank the valve has to be turned 180 degrees and I think it's this movement which is disturbing all that birds nest of pipework which surrounds it. Also it's all that new speedfit push in plumbing which probably doesn't help.
So, what to do? I much preferred the system in the Swift. 2 switches, an onboard pump and also an external pump in the aquaroll. No stupid levers and no plumbing layout which resembled the BR tracks at Swindon.
Do I -
1. Take it back yet again knowing the fix is only temporary?
or
2. Rip it out and re-plumb it like the swift was done?
I know option 2 will cause warranty issues and I know Elddis should be fixing this under warranty but to be honest, we want to use the van, not keep having to take it back for repairs. Don't think I'll buy another Elddis and have even considered rejecting this under the S&SoG act. All I want is a working van which doesn't drip water from the plumbing joints.
All help appreciated.
Dom
Do I -
or
Dom
