My water system keeps switching of at the control panel when not in use, Flojet automatic pump and accumulator set up, this occurs when turning a tap off for 30 seconds. 2008 Swift 480 Any. ideas.
Does the whole control panel go off? If so I had a similar problem on a 2008 Challenger 480. It turned out to be a bad connection. There is a join in the wiring (plug and socket) behind the fridge and one of the pins wasn't locked home in the plug and after a few trips the control panel worked intermittently. waggled the connection and the panel switched off - broke the connection and pushed the pins home and remade the connection - no trouble since. So check the connection behind the fridge, the one on the fuse board under the front seat and the connection on the back of the control panel.
Hi AC, Sorry for delay in coming back, On the main control panel above the door its just the water feed switch that cuts out, you can switch straight back on again and use a tap, then sometimes it will switch off again. The water is flowing and keeps running, then you realise that the pressure drops and the switch is off again.
Alan . Have you got an onboard water tank?????????? I hope by now you have managed to sort out your problem if not answer the post and Ill see if I can help Sir Roger
