im new to all this on panel lights are on for pump but no water comes out of tap used to make a whirring sound when it was on doesnt do taht anymore its a 1991 spectrum abbey please help a thirsty caravanman
sorry to be a pain damian but just to clarify the pump taking the water from the outside water tank is fine it just seems from the tank inside teh caravan to the tap is the problem like theres no pressure or somethingArran, check the pump connection to the van first, make sure you have 12v and the connections are clean and making good contact.
If nothing after that, it may be the pump is stuck, or has given up and needs replacing
