Whale ivan water heater not working on gas or electric
May 3, 2023
69
41
585
Gas supply is good, electrical supply is good. Water supply is good. 12 volt fuse is good, I have 240v supply to the heater. I have reset the red button. On the unit. I have switch off the HMI master switch for more than 20 seconds .
Regards caravan John
May 3, 2023
69
41
585
Hi mel tried that, to no avail. I contacted whale technical help ,and explained the situation. They seem to think I have 2 separate issues one with the gas and one with the electric, I am a bit sceptical about that. 2 faults at the same time?. I think one fault is common to both . Maybe locking out the gas . From the electric side. I am going to check all the connections on the 240 volt side and the 12 volt side. Keep you posted.
Reactions: Hutch and Mel
