Hi everybody a little help needed, i have a 1997 swift with the whale submersable pump, old fashion stlyle not pressurized , if i plug in the pump it runs all the time, even with all the taps switched off, i guess that could be a microswitch fault among the taps ye ?. what also happens and this is what i cant understand is when i turn on the switch to the pump it appears to stutter (on off on off) also the light on my switch goes on and off with it, i have never had any problems with these pumps but am i right in saying that they are sometimes suspect and faulty, ive read about some people having many pumps become faulty while others like me have never founfd reason to change one ? Lastly back to the stuttering fault i have metered the voltage outside where the pump connects and im getting 12 volt also tested the pump in the garage in a bit of water and a battery and water came through no problem ........any thoughts or is it just a knackered pump that aint up to the job, and i would have swapped the pump to test with another but aint got one , i dont want to be messing for hours when it could poss be a faulty pump.......any thoughts ? thanks
