Whale Water Master Socket Leaking Internally
Aug 4, 2025
Hi
2018 Elddis Affinity 550, looking for a bit of advice, the whale water master easy slide freshwater inlet is leaking on the inside, the leak appears to be coming from the joint between the water outlet and the plate that the IC is screwed against, I have replaced the the complete inlet unit, the seals and also bought a new pump assembly and it is still dripping water onto the floor below the inlet, any idea how to cure this would be appreciated,
