I’ve a BMW 320D XDRIVE SPORT AUTO ESTATE (2015) and I’m trying to find a caravan to tow.
The v5c for my car states “Max permissible mass 2160kg” and “Mass in service 1660kg”.
I assume the first is the maximum weight with the car fully laden and the second is the weight of the car empty.
Do I take the 85% as a percentage of the 1660 and that is the maximum weight I can tow?
The v5c also states “Technical permissible maximum towable mass of braked trailer 1600kg”
Im a bit confused.
Can someone please help☹
The confusing arises mainly becasue there are the bits that are law and others that are just advice, and over the years the advice has become almost regarded as law..... Yes confusing.
Lets just look at the law for a moment. On your car (not e on the V5) you will have a data plate that gives four limits, and it will look a bit like this
1 = Gross Vehicle Weight or GVW or MAM (maximum weight of solo vehicle)
2 = Gross Train Weight or GTW (maximum weight of tow vehicle plus trailer)
3 = Tow vehicles front axle limit
4 = Tow vehicles rear axle limit
These are all absolute limits and must not be exceeded, not even if advice suggests otherwise.
GTW - GVW = the maximum weight of the trailer when the car is fully laden. Sometimes car manufacturers will state the car can tow a higher value, but it means the load in the car must be reduced to make sure the combined measured weight of car and trailer does not exceed the GTW.
That's the legal bit, - Now the advice.
I hope its fairly obvious that a caravan is generally a big boxy trailer, and as such its going to behave very differently on the road compared to a small garden trailer. In recognition of this the UK caravan industry suggests that novice caravanners should limit the MTPLM of their caravan to just 85% of the
kerbweight of the tow vehicle This is only advice and not the law, so a few percent either way isn't going to be a problem provided it stays within the legal limits above.
The advice for experienced caravanners is MTPLM not to exceed 100% of kerbweight.
This advice does not offer guarantees about safety, that is more down to ensuring the vehicle and trailer are all in mechanically good condition, and the drivers driving habits.
If you are unsure about towing, then the caravanning clubs do offer towing courses to explain things and to build some practical experience.
The concern about your driving licence stems from the fact that licences issued before 1st Jan 1997 were automatically awarded entitlement BE (with dates) which allows you to drive a car and trailer of combined MAM up to 8250kg
Where as licences after that date were only given "B" which limits the driver to a combined MAM of 3500kg.
