Are you talking motorways here?Approaching your main road turn off there are usually three 100 metre count down markers 3:2:1.
When do you guys start indicating? Same for a right hand turn . How far away before indicating?
I’ve seen today some very dangerous manoeuvres on this
All roads with the 3 marker countdownAre you talking motorways here?
An example you are probably familiar with. Cirencester dual carriageway. Going from the Tesco in direction of Cheltenham I start indicating when I go under the bridge and see the island sign appear. I’m turning right at island to follow. Similarly when heading from opposite direction I indicate right when the island sign appears. I may be in the right hand lane already. Depending on traffic.
In motorways I start indicating at first ( your number 3) marker sign. But don’t decrease speed dramatically as don’t want rear end shunted. Tend to reduce speed on slip road.
Always at the initial marker. Number 3 on your list.All roads with the 3 marker countdown
For some drivers even if the car could read brain neuron activity the indicators would still not be activatedBuy an Audi or BMW, no need to indicate with them, in fact I don't think they have them fitted do tgey?
As part of my Advanced Driving training I was advised to accelerate up to 60 mph part way along the slip road so that I could then accelerate or decelerate to match my speed and slip into a gap without obstructing traffic already on the motorway.This is a very interesting thread, I live near to J 13 and J14 of the M1 and probably use the Motorway every 3rd day. How many people indicate when joining the Motorway.
I find it infuriating when drivers do not get up to a decent speed before blending into traffic. I try to get up to 60mph with the caravan, only to catch up with someone at 50 waiting for a huge gap to join into the motorway traffic.
To enable other road users to know my intentions I begin indicating as soon as the markers commence at Marker 3.All roads with the 3 marker countdown
I start indicating when the 1st sign is visible. My beef is those that see you indicating to turn to the left, but because you are slowing down they overtake you to turn left also causing you to brake a bit harder than anticipated.
The other is when you are in the inside lane going straight ahead while towing and the driver in the outside lane decides that they are going to turn in front of you causing you to stand on your brakes to avoid hitting them up the rear as they brake to drop their speed down from +70mph to about 40mph so that they can take the turn off! I now have dashcam camera in front and rear.
When I did a police driving course the advice was not to slow down before the slip road as following drivers may not be aware because there would be no brake lights. It could then lead to them either having to brake unexpectedly or as many do just shoot to the right into lane 2. Either action could cause an accident. The slip roads give ample time to slow down and following drivers are, or should be, attuned to vehicle decelerating. Mind you that advice was circa 1986 so has probably changed.
They aren't common but some motorway slip roads are very short with a sharp turn - so necessary to slow from 70 mph in lane 1 before moving into the slip road.When I did a police driving course the advice was not to slow down before the slip road as following drivers may not be aware because there would be no brake lights. It could then lead to them either having to brake unexpectedly or as many do just shoot to the right into lane 2. Either action could cause an accident. The slip roads give ample time to slow down and following drivers are, or should be, attuned to vehicle decelerating. Mind you that advice was circa 1986 so has probably changed.
