The inside and outside panes of a front window of our 2011 Bailey Pegasus 534 have separated. How do I remove the window so that I can glue them back together?
Hi welcome to the forum
Usually you have to remove the struts from the window by inserting something like a precision screwdriver in the pin hole on the handle and sliding up, then from the outside lift the window though 90 degrees and gently pull to remove the top of window from the chanel, refitting is reversal however the struts will slide back on without use of the screwdriver, it may take 2 people depending on the window. This video may help
Hi Algee welcome to the forum repairing a window is tricky business the acrylic has aged .
i would ring for a quote from this company called EECO Caravan Windows will effect a rebonding repair .
