window mist.
just back from a weeks break at the seaside.The front windows misted up between d/b glazing.Any idea what causes this ,and how to cleaqr it?Weather rather cold ,hence we had heat on low at night.
jim.
Jul 23, 2008
84
James.To get rid of the condensation in the window take out one of the bungs inside the window, that is misted up and wait till is all clear then replace the bung Not sure why it happens you might have some of the bungs missing try that anyway
May 11, 2009
13
Window misting usually, not always, occurrs due to air ingression as a result of the bonding that the two acrylic pieces are stuck together with breaking down. Most often it is an age thing. the advice offered will give temporary relif but there is no cure other than new window.
Apr 29, 2009
143
You are sure it's just misted up and not marked. There has been considerable problems with central front windows recently. There are several threads currently on the Technical and Equipment and Accesory sub=forums
I have the same problem ,windows misting at certain times of the day...took the plug out of the window (the plug split)never replaced the plug and the window still mists
PS were cab i buy a replacement window plug ?,all the dealers I contacted dont sell them
Miriad who are the UK agent for Polyplastic they will post out replacement bungs to anyone who needs them if you contact Richard on rtoon@miriad-products.com
