window problem
Apr 9, 2007
172
hi can anyone help?
I have a small leak from window seal on front of caravan the seals seem harder than the side windows, i think this may be due to them drying out from the sun.
If i was to spray them with bumper care from Auto Glyn would this sort the problem out or replace seal?
any help please thanks mark
Mar 9, 2006
265
Hi Mark, I have used Auto Glyn Bumper Care for this very purpose, and it definitely stopped any further leaks.(It's a liquid type polish, rather than a spray).
Nov 10, 2008
i would personally replace the seal rather than hoping the leak goes away, especially with the winter season upon us, its a cheap job to do, all seals etc available on www.leisureshopdirect.com and easy to fit if you take your time and use common sense, damp is something i personally would not like to chance as it will be alot more expensive in the long run!
cheers
Apr 9, 2007
172
cheers
Thanks Adam changed seals today what a job, my seals were 33mm and standard was 28mm and 30mm so had to travel around to find them few cheers mark
