Window rubber surround replacement
Sep 5, 2016
928
119
4,935
Can someone run me through the process
of replacing rubber window surround I have a damp issue and the rubber needs replacing it's not rocket science but what is the process,
936
Unscrew the stays for the window and the locking plates but mark where they should go back , use masking tape and stick to the van wall near the window rubber.
Remove the infill strip.
Remove all 100 or so staples you will find under the infill strip.
Pull the old seal away from the window.
Clean off any old mastic and repair any damp issues.
Starting at the centre bottom edge, fit the new rubber making sure it sits tight against the frame, especially in corners.
There should be mastic already present in the new rubber which seals the outside of the rubber to the van.
Make a good tight joint where the seal meets up in the centre bottom edge. Use a smidgin of silicone sealant on the mating edges to seal the join.
Put back the staples with new.
Refit the infill strip
Refit the locking plates and window stays in the locations you have marked.
928
119
4,935
Thanks for that info Damian very helpful indeed,
Sep 5, 2016
928
119
4,935
Damian, is it possible to get the infil strip back in with out the tool
