I never did anything as it’s galvanised, and my longest kept caravan never showed any sign of salt damage in nine years of usage all seasons. But to be pragmatic there weren’t many days when the roads were salted so it’s exposure compared to a car was very low.What if any, action do you need to take on the chassie to prevent salt damageing it ??
Morgan cars advised waxoyl or similar like Dinitrol for some models with galvanised chassis. The self healing characteristics of galvanising are limited to small damage such as scratches or chips. So I really do not see a rust protection fluid application being a problem.Danddandy, the waxy stuff I suggested was for the motor mover surfaces, before the minimum paint comes away.
I didn't realise that putting Waxoil onto galvanised steel was a problem, but like you would be interested to find out.
I had one caravan for nine years and used it throughout the year and its chassis had no problems with rust. Even in winter use the caravans exposure is likely to be far less than a cars. After all what is the probability of going to or from a site with salt on the roads. Quite low given mild winters and rain. Now if you live in Scotland it might be different. But cannot recall any Scottish members commenting on chassis corrosion.Waxoil should not be needed on a galvanised chassis, but it might be useful if there is any damage to the galvanising. I would not put you off but it is not something we do. Possibly a bit too late for this Winter though.
I would have thought that salt would only be a problem if you use the caravan in wintry conditions, so itmay depend on your use as to the possible benefits.
How much of that longevity is due to being washed down with fresh water after each immersion?I'm connected with the local lifeboat which is beach launched at least once a week winter and summer into salt water and lives in a salt laden environment. The current galvanised trailer is 15 years old and going strong with some pretty rough usage.
However any chips or damage to the galvanising should be touched up ASAP. I recall a product called galvafroid or there are aerosols of cold galvanising spray.
Some I'm sure, but that doesn't include the inside of the tubular chassis or the salt laden atmosphere its stored in.How much of that longevity is due to being washed down with fresh water after each immersion?
