Worn and loose caravan divider curtain
Mar 15, 2020
16
14
10,515
We have a 2010 Lunar Quaser 524 with a loose divider curtain whick keeps detaching from the plastic rail fixed to the roof of the van.
I am unsure if it is the plastic rail that is the problem or the little plastic clips on the curtain.
Has anyone else had this problem on an older van and has advice to share?
Many thanks
Ian
3,869
Yes I have the same problem on a 2013 Coachman 560. The heavier end piece of the curtain , will pop out when we go along, I found if I wedge a tennis ball under neath when it is stowed will keep it in place. We don't really use the curtain divider so it is not really a big problem.
Apr 23, 2024
152
123
135
I found the original curtain rail had distorted/worn with age on a client's old van so I replaced it with a standard domestic curtain rail , I attached a 15 x 15mm wooden batten to the roof , both screwed ( caravan roofs are generally 23-25mm thick so the screws should only protrude 16mm into it. I also glued it with PU expanding glue to make sure it was really secure.
