Zafira Petrols and Diesels - differing tow weights
May 20, 2006
I have recently bought a Zafira 2.0 Diesel. I note the max tow weight for a 1.8 petrol is approx 1300kg and the diesel is just 1050kg. Does anyone know the reason why bthis should be the case?
Nigel
2,902
It's an engineering limitation which GM won't publish the reasons for. Diesel Opel Zafiras may have a marginally higher towing limit, dependent on equipment fitted, but Vauxhall use a simplified limit which can't be over-ridden.
Current diesel Zafiras have reasonable towing limits.
I'm afraid you're stuck with a 1050kg towing limit until you change the car.
832
There are even Zafiras with a 1500kg maximum permissible towload (the 2 litre turbo petrol and the New Zafira 150hp diesel, for example). The problem with the old 2.0 diesel was engine cooling. The 2.2 litre diesel in the same model (never available in the UK, though) also had a 1500kg towload.
May 20, 2006
Do you think the problem would be overheating as opposed to safety - car/van weight ratio?
Nigel
832
Yes, the problem would be overheating. Like many other MPV's with a 'cab-forward' design, the engine compartment is relatively small and cramped. In combination with some engines, this can create 'hotspots' on some components which result in overheating.
As other Zafiras have a much higher maximum permissible towload without any significant increase in weight, the reason cannot be weight ratio.
