- Sep 19, 2006
- 3
- 0
- 0
I am new to this caravanning business - but having had 12 holidays since January - am enjoying it immensly as are the 2 kids and she who must be obeyed.
We have a 1996 Lunar Premiere -which someone must have mothballed as it was immaculate and unused when purchased.
My question is can someone point me in the right direction as to how to progress a problem with the battery and 12 volt system.
On the last but 2 holiday in July - we awoke to a strong smell of bad eggs inside and outside the caravan - I blamed it on 6 month old Emma but eventually found it was the battery gassing what I assumed was hydrogen sulphide - the battery was also hot to the touch. I turned everything off as I gather it can be an explosive gas.
Someone suggested that the charger rocker switch should not have been left on 24/7 and the battery could supply power to the 12volt system with an occasional charge which made sense - so on subsequent days and holidays I only used it a bit - all the time the battery guage needle was showing full. Water pump - 12 v lights all ok.
However at the weekend just past - when holidaying again - the battery was dead and didnt recover when the charge rocker switch was on. The cells seems to have lost water also I assume related to the boiling.
Would I expect the 12 volt pump etc to be run from the battery -through the charger (if on) - and does the system work with a dead battery - I would not really mind as we always use a hookup.
Also is my diagnosis that
1) The charge over charged the battery killing itself and
2) The battery survived a couple of holidays - during the summer so not much power draw other than water pump. When run down that was it
3) The new battery which I got from halfords and put in is now supplying the power but not being recharged other than when being towed. The 12 volt charger system is no longer playing a part in the operation.
Any advice is welcomed from you experts - given that I couldn't find anything that resembled a 12 volt charger when I unscrewed the electric panel are they inbuilt into that ? - in which case we could be talking big money.
Would taking a stand alone charger and using that from the mains be a better cost option.
I am not planning on doing any electric work as unqualified but just trying not to fall into the gullible customer waiting to be fleeced trap.
Best Regards Richy
Best Regards Richy
