12 Volt Connection
Oct 30, 2007
14
I have bought a Satellite Suitcase from Maplins and need to take a 12 volt connectio to the front of my van. Where is the best place to start a connection? Any further help wiyh one of these items would be appreciated
May 7, 2007
361
Hi Arthur,
The sat dish does not need a 12 volt connection if that is what you mean, can you be a bit more specific in what you need the 12 volt connection for.
Regards
Graham (Ponty)
Sep 13, 2006
1,411
Most vans have a 12V supply and aerial connection in this position anyway.If not and your fuse box is under the seats at the front of the van this would be the best place to take it from and it would be best to take the feed from the existing fuse for 12V ancillaries.
Oct 30, 2007
14
Hi Arthur,
Regards
Graham (Ponty)
Thanks for the reply.
I need a 12 volt connection at the front of my van for the receiver and the 12 volt television
Oct 30, 2007
14
I dont have any 12 volt at the front of the van
(or ariel point) But I would like to operate my TV at the front instead of the middle so its not in the way when my wife is preparing food Not sure where the fuse box is will investigate.
Once again, thanks
May 7, 2007
361
Hi Arthur,
I assume from your last post you have a 12 volt TV, do you have a Pace 1000 12 volt sky digibox as well or do you have a freeview box.
Graham (Ponty)
I would take a lead direct from the leisure battery via an in line fuse for both the +ve and -ve
Use fairly heavy auto cable (say 35amp) to avoid voltage drop over the cable length which affects TVs a lot
I have had to do this on a few vans as often the factory fitted cable is too thin etc
Oct 30, 2007
14
Hi John,
Thanks very much.
Most helpful regarding the cable thickness as I am a complete novice in these matters
Mar 11, 2007
585
Greetings John G
Can't help but wonder why you recommend a fuse in both the poss andd neg cables.
Brum
