Our Indiana is on the drive hooked up to mains from the house. We leave the electric Truma (240v) heater on very low for frost protection, but also with the Trumavent fan (12v) running slowly to help ventilation. On my regular checkup this weekend I found that the mains was working (sockets fine, and indicator light lit on the heater control) but no 12v services at all. Battery condition meter reading zero. I connected a separate charger to the battery (110amph)with mains disconnected from the van and the found 12v services instantly came on, and meter reading about 13.5v. I then removed the battery and left it on charge at 16amps for 12 hours - now showing 100% charge. My conclusion is that the battery is OK but there is a fault with the caravan charger.
Does anyone disagree with this diagnosis? If so what other things could cause these symptoms? Is it a DIY job to change the charger, as it is a bit of a chore taking the van back to the dealer? The van is 13 months old, BTW, but the charger was replaced by the dealer last May following completely different fault symptoms!
