Electricity and myself don't get on too well so any answers, if you could keep them in simple terms please.
I am experiencing an occasional problem with my 12v compressor pump when using it powered by one of the two 12v sockets in the caravan. The pump is a Ring Automotive model, it's about two years old but seldom used. I use it only with the van either with the Floe system for draining the water pipes or to top up tyre pressures when required. It has what I would term as the normal push in plug socket.
Twice when I have used it the 10amp fuse in the van 12v system has blown, first time it happened I thought it was a one off and changed the fuse. The pump then worked fine again. Just before my recent trip away I was checking tyre pressures when the same happened again. I have used it without problem between these two blown fuses without problem. The pump itself has a 10amp fuse in the plug socket which hasn't blown at any time.
Does the fact that it's the caravan system's 10 amp fuse that is blowing suggest the problem lies within the van's system?
