- Oct 31, 2009
- 2
- 0
- 0
We are close to buying our first caravan and I'm gathering as much info as I can to be better informed.
I'd like a little more information on the issue of charging the caravan's battery from the car. Information on the 'net and in the Haynes caravan manual is very useful, but I'd be grateful of a few points to be clarified please.
When it's said that the caravan is charged from the car's alternator, I'm assuming that the battery is charged from an appropriate 12V feed direct from the car's wiring. Are the batteries used in caravans (leisure batteries?) similar in construction to a standard car battery (with the same charging criteria)or are they sealed gel types that require special constant voltage charging?
Am I right in thinking that protection relays are used to prevent a massive current draw from the caravan's battery when the cars's starter motor is used?
kevin.
kevin.
