12v System
Aug 28, 2018
26
I have a Sterling Europa 550 2010 12v System does not work. i' not the most confident with electrics, just wondering if there are any checks i can do myself before calling someone out?
Mar 19, 2019
76
Read your manual, if nothing works without a mains hookup, your battery might be knackered, there may be a main switch you need to press, or maybe your main fuse needs replacing.
Beyond that, what you can do depends how confident you are using a multi-meter. If your not confident with that call someone out.
1,819
Not sure how you tested it. I would try two different 12v items and if neither work then there is a problem.
The caravan will have a battery check provision which should be a push button on the control panel. That will either show the voltage at the battery or light up red for flat, green for fine or amber for fair. I am not familiar with your models electrics so do not know for sure exactly what you have. If the battery is OK check the fuses but after that unless you are competent with the wiring I am afraid you probably need professional help.
9,548
If it’s a Sargent electrical control unit it should have a small dark push switch over the 12 v fuses. Mines an EC 400 and that switch has to be pressed in for the other control panel to show any information. With that switch “in” you can then use the controls on the display to look at battery levels, pump on/off etc.
If it’s similar to mine that switch also has to be ON when towing.
Sep 5, 2016
928
119
4,935
Shakeyblade, I have the same caravan, what is the battery indicator showing which is over the entrance door,
