13 pin electrics
Dec 30, 2009
1,662
Hi, were getting a new van in a couple of weeks and it will have 13 pin electrics with it. I would like rewire the 2 7 pin plugs to a 13 pin plug on the car, I can splice the cable together but does anybody know the correct positions on the 13 pin plug ie pin 1 on 12n into ?, pin 2 ect ect ect
thanks
Kevin
Dec 30, 2009
1,662
Hi David thanks for that.
I understand the 12 n into the 13 pin however the diagram both on towing trailers and western towing dont seem to match up 1 to 7 and 8 to 13 unless th diagrams use 2 different wordings??
so no further forward
Kevin
Jul 6, 2007
265
If you Google "13 Pin Wiring" there is a mind of information and wiring diagrams and pictures.
Forgot to add if you are a member of the Caravan Club, log into their website, where there is a Technical Information Leaflet you can download,under Practical Advice, which should answer all your problems.
G
Guest
Having a van where the dealer reversed from the 13 pin set up back to the 2 cable set up, to be in line with UK normality, I do wonder if it is really such a big deal. The car is now fitted with the 13 pin socket. Yes, I have the adaptor cables and I tie them up to the jockey wheel and no trouble at all. You can get ones with very short length.
To do this properly to my mind would suggest changing the cable back into the van back to 13 pin cable.
Jun 11, 2012
1,525
28
19,685
Hi Trucker ,me being a coward I have just done the opposite to our outfit , the tow vechle is 13 pin so I spent the money and bought the lead already made up so if things need to change later I just remove the ready made up lead.
I couldnt do with hastle
Good luck anyway
Regards Sir Roger
Dec 30, 2009
1,662
Done the job yesterday, used the diagram from this web address (it was the easiest to follow)
The only problem I had was the 12s pin 2 and pin 5 where to put them.
Phoned Western towing in Exeter where I had it fitted 18 months ago and got the answer.
Pin 2 was for battery charging and is not used on the 13 pin system (battery charges from fridge pin whilst it is on!!) and pin 5 was never used
Followed pin 2 wire blue back into car and disconected as it was live and job done.
Well hopefully as I pick up the new van next Saturday.
http://www.scribd.com/doc/2173751/Caravaning-How-to-13-pin-wiring
thanks for all the replys
Kevin
2,399
Copied from the New Members section for Tom :
I need to fit 13 pin electics to our new Zafira. Vauxhall, for 1 manufacturer, do a 13 pin kit which plugs into the fuse box located in the boot. Does anyone know if this is only for the road lights, or does it cover all the electrics (fridge & battery)? HELP
G
Guest
I do not know and would suggest asking Vauxhall. A 13 pin set up should do everything but sometimes the installer only thinks you are towing a trailer, not a caravan and only connects the basics.
