1996 Elddis Wisp electrics
My water pump has stopped working. Its the type that you drop into the water carrier outside the van and plugs in the side.
Before I go buy a new one, wanted to check the electrics. I have turned the taps on and had a meter in the socket where the pump plugsin on the outside of the van and it registers no volts, so I assume its in the van. Anyone know where there may be a fuse box? I can see a set or trip switches but cant see a fuse box.
Ian,
I assume the pump switch is on in ther van? Silly Question really... You may have a microswitch problem on one of your taps. Do you get any 12v at the pump with all your taps switched on? If you have a pressure switched system then it may need adjusting...they are sometimes voltage sensitive.
