- Sep 9, 2008
- 8
- 0
- 0
Lovely van, but currently staying with Discover Newport for a lengthy warranty list. Two items are going to be interesting, both concerning electrical equipment:
1. The electric water heater, which is apparently automatic (ie. no 'on' switch apart from on the 12V circuit-breaker board) has never worked properly and stopped altogther at the beginning of August. Discover suggested it might have 'tripped' because we emptied the hot water tank when it was hot (doesn't everyone?) and described a complex procedure for putting it right, which made no difference whatsoever. None of this is mentioned in the manual - as far as Swift are concerned, it simply works.
2. The refrigerator has a worrying habit of failing on a mains connection and defaulting to 12V, which is an excellent recipe for losing food if you're out for the day. This is not an isolated event and I wonder if other 'fridges default in this way, regardles of whether they fail as frequently as ours does.
I get the impression that caravan electrics are getting over-complex and I'd much prefer the level of manual control I had with my previous 'van. Anyone else had similar problems?
