Hi, I would like to fit an external 240v socket to the awning side of my Bailey Champage, is this better left in the hands of professionals or is it a job i could do myself, any help greatly appreciated.
Thanks for the advice, much appreciated. IanIt can be done yourself, but as you are asking the question I assume you have doubts about your technical skills in this department. It is also daunting to cut a hole in the body panel. Therefore get a dealership to do the job for you. It will not be too expensive and can be done in an hour or so. They will fit a flush mounted box with a outdoor socket inside. They will then connect this to the RCD and you are in business. It is best to fix this where there is a seat base on the inside to cover the wiring.
Thanks everyone i am going to give it a go!That is a very good link and I have saved it to favourites as it comes up often
I have fitted a few of them to my own vans and recently fitted one withe 230V and 12V outlets
I have never found it necessary to make a wooden frame and I prefer the type of socket that can either be stuck in with a sticky pad or used with a short pull out lead
I usually use an old but good lead saved from an old appliance (3 core from washing machine etc)
Its easy then to locate say the fridge/microwave socket etc and with a double adapter just plug in the old lead and you have an extra fuse in the plug
If you use mastic tape you should have no problem with damp ingress and warranty concerns at that point
I always make the outside of the cardboard template a lot bigger than the area to be cut out and start with a hole drilled at each corner before joining with jig saw or pad saw
