300 spartans
OK, i've got the film 300 on dvd and i've just got one of these nokia n95 8gb phones, how do i get the film to the phone in real player format.
Come on you geeks where are you.
Martin.
Download the latest version of Nokia Suite from their web site, but fist remove any earlier versions from the pc/laptop you connect the N95 to.
On the Nokia web site go directly to the download button at the bottom of the screen without selecting your phone model!
Set-up PC suite to connect via the included with phone usb cable.
PC suite settings tabs open options for music and video download and auto video conversion to .mp4.
Once you've set-up Nokia Suite, connect cable from pc to phone and on phone select Nokia Suite on the phone screen and you'll see a connection icon on the phone.
On the PC's Nokia Suite screem you should see Nokia N95 8GB as the connected phone. If not, close an reopen or go to phone selection and make sure you have the phone recognised by PC suite window on the pc.
Nokia PC suite has a "drag and drop" feature on the left of the window (phone picture area).
You should then be able to insert DVD in to the PC, open the My Computer screen on PC and drag the DVD to the "drag and drop" area where it should be converted to .mp4 format.
PC suite is used for back up of the phone and the transfer to and from of data, video,music and Outlook contacts/calendar entires etc between pc and phone.
Nokia Suite will not load video if encrypted to prevent copying I'm told, you'll need to use www.dvd43.com or similar and get the video files unscrambled before you can drag and drop to the phone.
Good luck.
Good luck.
ps. I've had slapped wrist from son in-law.You also need Nokia Vieo Manager downloaded from Nokia to make it all gell together.
And even more good luck 😉
