Has anybody towed with a 4x4 spare well cycle carrier fitted? Does it interfere or contact the van? Any advice would help as thinking of buying one. Thanks Andy
http://www.roof-rack-supplies.co.uk/cycle-carrier-4x4-ranger.htmhi,
i bought the paddy hopkik 4x4 rear spare wheel mounted.although this worked fine,found i had to take pedals off bike car side as it caught the bodywork.never had any trouble with the van on journeys.be sure to take it off before you monouvre you caravan into position on site,as sharp turns it will catch.
Thanks Clive but no space as six of us in the car. AndyI remove the spare wheel to carry inside the car and use a Witter cycle carrier
Thanks sounds like a case of trial and error then. Might get a second hand carrier and try. AndyI towed with a two bike wheel rack on a Defender 110 towing a Castleton. With the steering lock of that vehicle it did not foul going ahead, but in reverse it was all too easy for the bikes to contact the van's front.
Nobody can really answer your question as there are too many variables. Vehicles differ in steering lock, wheel offset and wheel height. Caravans vary in "A" frame length, shape of front and position of Jockey wheel. Bikes differ in size etc and racks differ in how they sit on the wheel and how they hold the bikes.
Mine was in most respects a tolerant set-up but it was not a good solution and very inhibiting when backing onto pitches. I suspect most other combinations will be even less satisfactory. If you van is a Continental one that features a long "A" frame it should work out better.
Thanks Klarky sounds possible will give it a try. Andyhi,
i think jtq has it spot on,everyone is not the same.Thanks sounds like a case of trial and error then. Might get a second hand carrier and try. Andy
