I've just bought a 150watt inverter from maplins £14.99 in the sale. I only want to run a small telly or radio for a short while for the weather forcast etc so reckon the drain on a 110amp/hr battery shouldn't be too much of a problem for a few days away without hookup.Can I wire the inverter direct to the battery and then feed the 240v direct into the vans mains inlet via a 240v plug and blue caravan mains socket so I can use the plug sockets in the van? also the inverter is supplied with a cigar lighter plug which I will remove, and an earth terminal. when/if it is used in a car for a laptop etc where would this earth be connected to the car?
Hope you can help,
Cheers,
Paul
Hope you can help,
Cheers,
Paul
