Aerial Problems - Again !
Oct 23, 2008
12
Hi,
I have a similar problem. I have a normal aerial socket in the caravan and a status box in the overhead locker. The status box has two aerial leads by it - one I presume feeding from the aerial on the roof and one that plugs into it and goes to my aerial socket above the fire ??? - but I'm not sure and I'm not getting a signal ?
Can anyone advise please what the problem(s) may be ??
Simon
Feb 13, 2006
80
What shape is your aerial? Round or torpedo shaped?
Most vans have a feed to both the front and the back of the van. There is usually one input from the aerial and 2 outputs.
It also depends whether you are trying to get digital.
How old is the van?
Status aerials are just loke domestic ones that use an antenna and a booster. Plug the lead from the antenna directly into the TV and see if you get a picture. It is well known for the boosters to fail.
