Jun 28, 2010
12
hi there.
i'm a bit new to all this so please bear with me.
i have an image digital aerial on a pole onmy jockey wheel.
i can get a perfect picture with a really old portable tv but when i connect my new 22in flat screen i just get a blue screen and the message , no signal is being recieved, any ideas please?.
many thanks garry
2,399
Hi Gary
when you have connected your aerial have a look around the campsite to see which direction other aerials are facing and turn yours the same way.
On your remote control will be a button which will switch the tv between digital and analogue reception, make sure that digital is set.
Then press the menu button and the installation programme will appear. Select 'first time installation' and the tv will find available digital signals.
You will need to retune your tv using 'first time installation' every time that you change locations because the digital tv signals will use different frequencies in different areas.
