Will go and check, 8 springs to mind.Are you sure about the 8psi? The instructions with my Sunncamp Airvolution say a maximum of 7psi (12,5% less)
It would take around 13 degrees C increase in temperature to put the pressure up from 7 to 8 psi.I never actually inflate to even 7psi, only just over 6. My theory being that in strong sunlight if inflated to 7 the solar gain will increase the pressure in the bladders to way above 7 psi and that might lead to one of them bursting. I have no idea if Sunncamp have allowed for this expansion in their 7psi instruction.
Hi Dave i would pump to 7 psi onlyThe instructions on my Sun Camp 220 is 8 to 10 pounds. From what you say this is high, shall stay well below that .
PS I'm now going to find out if my pump has a relief valve.
But surface temperature of the material could higher than ambient air temperature. Just like track temperature for F1 or MotoGPIt would take around 13 degrees C increase in temperature to put the pressure up from 7 to 8 psi.
Am I glad that I stuck to awnings with poles. Although on hot days the aluminium poles would extend and stretch the material risking damage so I had to go round and readjust, but when I changed to carbon fibre that issue went away. 😱Following on from Sunncamps rather patronising, and frankly useless, response to my email I have sent them the below.
Watch this space!
Thank you but you haven't really answered my question as to what, if any, "leeway" there is in the recommended 7 psi inflation pressure.
In addition please can you explain how I can effectively, and constantly, "monitor" the pressure within the tubes? The supplied pump has a pressure guage, but that only shows pressure within the pump. There is a non return valve within the inflation points and that prevents the guage being able to display the pressure present within the tube.
As there is a pressure relief valve within the pump why do you not fit a similar item to one inflation point? Why not offer one as an optional extra, or even better a pressure guage that would allow an owner to see at a glance what their beam pressure is. I would certainly buy one.
In addition how exactly do you propose, as you have rather glibly suggested, I "monitor the pressure" when I have left my caravan and awning and am having a "day out" when what was a dull overcast day becomes one with blazing sunshine which will greatly increase the pressure within the air beams.
I know some companies can be frustrating but can I just draw your attention to the following community rule, which you're coming close to overstepping.Following on from Sunncamps rather patronising, and frankly useless, response to my email I have sent them the below.
Watch this space!
SamAvoid "calling out" or attacking specific brands or companies in an effort to shame them with your experience. Take specific complaints directly to that company so they can work with you to resolve it.
No worries...Sam
I am certainly not trying to "call out" or criticise any company, and have been very careful not to say anything at all critical about the product (which I am very pleased with) . I am just trying to elicit some practical advice in regards to their product for my, and anyone else's, benefit. I just thought others might like to see the communication trail.,
If it is considered I have overstepped the mark then please feel free to delete my last post.
