Hi All,
Hope someone can help. Have purchased an AKT 50w + 50w solar panel with a separate connector box. Having a problem working out how to connect the two panels together and then connecting to control box.
The back of the panel both have the diode boxes but only one has leads coming out of it. I assumed these connected to the other panel but they do not as the ends of the leads do not fit into the panel box. They will fit into each other as one is a male and the other a female connector, but this does not connect the other panel and also does not connect in to the connector box. All I can acheive with what I have is either two loose leads (a pos and a neg) or a loop from the one panel and a loose unconnected connector box.
Any ideas would be welcomed
